Xm V Delavnici
No ker se poletje Bliža in bo vročina v moji črni bežtji vedno večja me zanima če ima kdo tel.?tevilko serviserja klimatskih naprav po preimku Parkelj iz Rakove Jel?e v LJ. Sem jo imel pa nevem kam sem jo zaločil. Bi vljudno prosil če ima kdo ?tevilko.
psihopat100posto
moj je 24.v ja. Ja na tvojega bi pol šel tudi Venturi lahko gor recimo, pa bi pri?paral mucho dinero, samo pol tudi performansi nebi ostali tako kot je treba.
?e kdo ve rabim regulator pritiska, no to zadevo na kateri je centralna bunka ki uravnava pritisk za hidravliko. Mi malo pušča pa bi rad zamenjal, sicer nevem ?e so vse med sabo kompatibilne al je treba spet za točno določen model naročit. Nebi se rad spet spuščal v naročilo pri CitroenKoper, ker sem ?e na hidravli?ne lajtunge pri njih čakal 1 mesec!!!! da ne govorim o tem, da sem ceno zvedel komaj ko sem jih dobil, neresnost do konca za moje pojme.
No ?e ve kdo kaj o tem regulatorju in kje bi ga lahko nabavil se Priporočam za info.
lp, Vlado
A je že kdo slučajno to preizkusu?! Pred časom nazaj mi je toni ta problem že omenjal zdej
sm pa ta externi regulator našel na e-bayu.
Pravi pa tako:
The majority of XM's (even low mileage and well maintained ones)
 have lost the "magic carpet ride" they were designed to have.
Owners are enduring sub-standard & harsh ride quality (for an XM)
 that's little better than a "normal" car.
Even after replacing spheres - the improvement is only marginal.
So called "comfort spheres" are available - supposedly in an attempt
 to counteract this problem (didn't Citroen intend theirs to be
comfortable then)?
Many garages - including Citroen dealers - won't even diagnose the
problem.
Many XM owners have never experienced the level of comfort their
 car was designed to provide.
So what's going on? Here's the full story - and the solution..
When Citroen introduced Hydractive II suspension to the XM in
 February 1993 (left hand drive models from RP No. 5929 onwards
& right hand drive models from RP No. 6383 onwards) the two centre
 spheres were operated by individual electro-mechanical firmness
 regulators. These regulators switch the centre spheres in or out
 of the hydraulic suspension circuit to make it softer or firmer. The
 suspension ECU (computer brain) monitors a variety of sensors
(acceleration, body movement, steering etc) to detect the way
 the car is being driven and independently operates the firmness
 regulators to make the suspension firmer - and the car handle
better / more safely - when necessary, and for the rest of the
time to make the suspension softer - making your journey as smooth
 and comfortable as possible - the legendary "magic carpet ride".
You can also select "sport" suspension using the slider switch on
 the centre console. Contrary to popular belief this does not set
 the car permanantly in firm more - cutting the centre spheres
out of the hydraulic circuit all the time - but means the suspension
 ECU will activate the firmness regulators more readily (in anticipation
 of you making greater demands of the car).
So - what goes wrong? It's really quite simple. In each of the
electro-mechanical firmness regulators there's a component that's
 designed to protect the electronics in the suspension ECU. These
 components fail - and when they do the suspension ECU detects
the failure and to protect itself shuts down the circuitry that controls
 the electro-magnetic firmness regulator. When this happens the
firmness regulator - by default - remains permenantly in firm mode.
This can happen to front or rear firmness regulators - or both. In this
 state the ride is much harder than when you select "sport suspension"
 because the regulator is never able to operate in soft mode and it's
centre sphere isn't switched into the hydraulic circuit at any time.
So what does this kit do and how does it help? Quite simply - this
kit replaces the components that commonly fail for both firmness
regulators. Just as it detected the failed components - the suspension
 ECU will recognise that the components are working and will immediately
 activate the circuitry that controls the electro-magnetic firmness
regulators - allowing full suspension function! The failed components
 in the firmness regulators are encapsulated in the body of the unit
 and can't be replaced so this kit replaces them elsewhere in the circuit,
 this time closer to the suspension ECU. This means they're just as
 effective at protecting the suspension ECU and the kit connects easily
 to the wiring loom where access and identification is straight forward.
 See pictures below. The kit has only three wires and comes with clear
 instructions specific to your car. All you need to provide is the vehicle
4 digit RP No. that's painted on the near side front door pillar. There's
no need to cut the wiring loom and there's no soldering involved
 because the connections are made using Scotchloks that tap into
the existing wiring. All you need is a pair of pliers to close the Scotchloks.
 All work is carried out under the bonnet simply by opening the lid on
 the ECU container above the off side front wheel. (You may need to
 remove and replace the first few inches of insulating tape from
 around the loom as in the picture below.)
This kit is available for all XM models from RP 5929 onwards (LHD)
 & RP 6383 onwards (RHD). Just provide LHD/RHD and your RP No.
What else should I know? I think you'll be astonished at the results
 you get from fitting one of these kits. It's probably the biggest
 difference you can make to your XM relative to the cost & time
 involved! If the component in only one (front or rear) firmness
regulator has failed you can still fit this kit because having more
than one functioning component in the circuit is perfectly OK. It's
 actually a good idea to fit a kit even if neither have failed -
because this will prevent the problem from ever arising. The
 replacement components I use are "heavier duty" than the
originals and so are not going to fail again. If you prefer I can
supply the kit using original components. The kit is designed to
 do a specific job - but it's not going to compensate for spheres
 that need replaced / re-pressurised for example! (Front spheres
 should be done every 3 years and rear ones every 4 years.
There are 3 on the front plus 1 accumulator & 3 on the rear
plus on later models an anti-sink sphere at the rear. The hydraulic
 system should be flushed and LHM renewed every 5 years.) If
your car has suffered from this fault over a long period - it's
 possible, despite the sophisticated protection circuitry, that
 ECU control components will have overheated and failed. If
this is the case you may not benefit from this fix until those
 components are replaced. In such circumstances however
- fitting this kit is a useful and cost effective aid to diagnosing
 ECU control component failure. If your ECU components have
 failed I can offer a professional repair using original components
 and can assist with a replacement ECU (depending on model) to
 keep your car on the road. There's obviously an additional charge
for ECU repairs. [Terminology used - i.e. n/s/f - relates to right
 hand drive.]
Please contact me if you need any further information.
XANTIA VSX & EXCLUSIVE HYDRACTIVE II SUSPENSION FIX KIT
 - COMING SOON!!
Suspension ECU is inside the container above the o/s/f wheel
Connects to loom that feeds the white 15-pin ECU socket
(front right) ..
Scotchlock connectors to tap into existing loom ..
(view from above - white 15-pin socket now on left)
Job complete in around 15 minutes..
Correct wiring for your car - provide LHD/RHD & RP No..
RP number located on n/s/f door pillar.
Your Satisfaction
I hope you'll be really pleased with your purchase. If you're not
 - or if any problems arise - please get in touch with me straight
 away and I'll do everything I can to put things right for you quickly.
If you're not 100% satisfied with this purchase simply
Tu pa je link na e-bayu:
http://cgi.ebay.co.uk/CITROEN-XM-SPHERES-HYDRACTIVE-II-SUSPENSION
-REPAIR-KIT_W0QQitemZ190099672845QQcategoryZ10376QQrdZ1QQcmdZ
ViewItem
psihopat100posto
ja hvala za linke, bom poklical v Herkules v torek, na myparts pa nisem našel tele zadeve, a ve? mogoče pod kaj bi mogo iskati?
Citat od: psihopat100posto;4253ja hvala za linke, bom poklical v Herkules v torek, na myparts pa nisem našel tele zadeve, a ve? mogoče pod kaj bi mogo iskati?
čuj nimam pojma ponavadi dobi vse kar rabiš lahko tudi obnovljene stvari. če nima na internetni trgovini pa mu pi?i na mejl. Ponavadi dobi tudi dele, ki jih nima na listi.
Imam eno vprašanje. Zanima me namreč dimezija oz. fi (premer) dize - injektorja. Ne najdem nobenega podatka in posledi?no nevem kakšen premer je. Ali je 1,5mm ali 2,5mm? Motor je ZPJ/SZF 123kw. Po pravici povedano ne bi rad zdaj demoliral injektorje in s ?ublerjem meru.?
Ima kdo INFO?
Hvala
psihopat100posto
glede injektorjev: mojster ne ve kakšen je premer, sva tudi gledala po katalogu pa ni napisanega podatka za premer injektorjev. Mi je pa rekel, da so ozNašeni z barvami, se pravi imajo gor plastični obroček po katerem se pol ve kakega je treba naročiti pri morebitni menjavi, pravi da je vsaj taka praksa pri naročevanju injektorjev v ?tacunah in skladi??ih.
lp, Vlado
Vlado hvala. Zgleda, da bom mogu na koncu veeno odmontirat injektorje.
LuCit
Eno vprašanje.
Prej?n tedn sem imel karambol:funny34d:.... Pa moram zamenjat masko, odbijač, pa ?e mal levga blatnika moram poklepat. Pa me zanima kje izvem kodo barve in kje potem kupim to barvo?(citroen servis, drugje..?) Vem da bi bilo najbolje dobit kose v pravi barvi samo jih ne najdem.
Kakšne barve bežtjo ma??
LuCit
Citat od: LuCit;12041Evo ga:
To ma? ti grafitno sivo oz. po katalogu Gris Silex?
LuCit
Samo to se mi zdijo bolj vzorci za tkanino, pa mal pretmna barva se mi zdi.
No sm ?e nekrat pogledal v katalog pa se nism nič zmotil. Na levi strani kataloga so barve, ki sem jih prilimal na desni so va vzglabniki oz. demonstracija palete materialov za notranjost. Razlog, da barve delujejo kot nekakšna tekstilna tekstura pa je v skenerju. žal sem moral pomanjšat format in rezultat je bil slab?a kakovost slike. Bom poskusil ponovno in bomo videli ?e bo kaj boljše.
