Nova različica za MyWay (RNEG) 40.03
Začel/a Dr. MadMan, Maj 17, 2012, 08:41:32 DOPOLDNE
Dr. MadMan
Na povezavi https://www.sugarsync.com/share/707d040ea8a676
je na voljo nova različica sistema za MyWay (RNEG) navigacije. Odpravlja določene napake ki so naštete spodaj. Kolikor sem obveščen še vedno ni streamanja prek BT.
Odpravljene napake:
-Various Bluetooth malfunctions (Incompatibility with certain telephones, loss of the Bluetooth twinning on starting a telephone call, poor sound quality)
 -"UNKNOWN" is shown instead of the name of the caller when receiving a call
 -Under-estimation of the radar speeds for vehicles with the speed unit in miles
 -In Latin America only, restarting of the audio-navigation system (RNEG) following a request for navigation in "Demo" mode
 -In navigation mode : Cursor stuck on the GPS mapping, The cursor on the GPS mapping does not reflect the actual position of the vehicle
 -Arrival time either over- or under-estimated when being guided
 -Random loss of audio adjustments after starting the engine
 -Random loss of audio sound after starting the engine
 -Interference in the loudspeakers after starting the engine
 -Multifunction screen randomly going yellow
 -Random loss of time and altitude
 -The telephone directory, or the history, of calls made from the radio-navigation system RNEG is no longer visible on the multifunction screen
Dr. Navigator
Kreativne IT rešitve
https://www.greit.si
https://www.archistudio.si
slovenia17
Pozdravljen
Povezva ne deluje. To je za novi C3?
Hvala in srečno
Dr. MadMan
Pošlji mi mail da te dodam med uporabnike.
Dr. Navigator
slovenia17
matt79
živjo
vprašanja: imam RNEG avtoradio in mi poveže takoj telefon, vse deluje normalno, problem je ker ne morem dostopati do mape z kontakti, izpisana je vendar ko se gre z drnikom čez meni to mapo preskoči.
preko BT sem naložil Vcard kontakte katere je uspešno sprejelo venar jih sedaj ne najdem v meniju? kje naj bi bili naloženi??
če poskušam shraniti kontakt direktno preko radia mi pri shranjevanju le tega izpiše na zaslonu navigacije PLEASE WAIT in to traja in traja in mislim da ne bi nikoli shranilo.
kako deluje ta radio, on pobira kontakte direktno iz telefona ali morajo biti shranjeni v radiu??
hvala in LP
Si preveril če nimaš mogoče kakšne funkcije v telefonu izklopljene?
Avto pobira kontakte iz telefona, mislim da jih ne shranjuje v avtu, ker ko telefon ni povezan jih ne vidiš ...
Moj telefon (S Galaxy S) se takoj poveže z avtom, potem čez nekaj sekund, tam kake pol minute pridejo še kontakti .. medtem ko se povezuje, vidim na telefonu napis "zahteva za dostop do imenika" oz. nekaj takega, zdaj govorim na pamet ... bom pa jutri preveril, ko pridem do avta.
Mogoče pa imaš blokiran dostop do imenika in se avto ne more povezat ...
matt79
imam dva telefona Samsung s3350 chat navaden klasičen telefon, kateremu sem pooblastil dostop do citroena, ter drugega Samsung galaxy xcover in tudi pri temu ne najde imenika, če imaš kakšno idejo kje se da to vključit bi prosil za info.
north
Èisto tako kje imaš shranjene kontakte na sim kartici ali na telefonu lahko da je to vzrok da ne najde imenika, mogoče radijo samo iz sim-a pobere imenik ali obratno samo iz telefona  ???
Citroën - Creative Technology
matt79
najprej sem imel na sim kartici nato sem dal na telefon označil da pobira iz telefona in nič ne pomaga.
vseeno me pa zanima zakaj ima ikono diskete kot da bi se lahko kontakt shranilo v avto vendar čaka in noče shraniti?
Johnzy
Zdravo.
Najprej ena velika zahvala Dr. madman-u za linke in mape za moj RT3.
Zdaj mam pa spet en problem pri taščini navigaciji C4 - MyWay (rneg_D_R27.bis_R27.01)... mi nekako ne potegne SD kartice - napiše da kao ni navoljo (kartica je 16Gb in nanjo je po navodilih naložen database iz SS, pravtako je popravljen volume id na serijsko katera je v navodilih...) zanimivo mapo in zemljevid pa vseeno kaže???
... samo lej ga zlomka ko sem pa zopet vstavil staro SD kartico se je pa problem pri stari ponovil.
Je kakšen pravilen postopek menjave kartice, mogoče kakšen potreben reset sistema, ali enostavno nadgraditi sistem na novo verzijo 40.X katero najdem na SS. (se ta posodobitev naloži tudi preko SD kartice ali kako drugače, ker za posodobitev ni navodil...)
Hvala za odgovore.
Janez.
Dr. MadMan
Dr. Navigator
