Popravilo motorckov za centralno zaklepanje na C8
Začel/a sivac33, Marec 14, 2008, 10:13:33 POPOLDNE
sivac33
Mislim da pride okoli 200e, ker za xsaro pride okoli 150e.
michoBX
Odstrani oblogo z vrat - potrebno z torxom(zvezda) odviti 4 ?raube (dva sta skrita za notranjo kljuko, po eden pa ?e na spodnjem delu vrat - levo in desno). Pa preveri, ?e prav vem gre za mehansko napako, tak da malo premigaj tiste vzvode, pa se ti mogoče pokaže napaka...
Nekaj sem zasledil tudi na netu, ?e zNaš angle?ko;
CitatCAN ANYBODY HELP . THE REMOTE CENTRAL LOCKING & REMOTE OPERATION OF SLIDING DOORS FROM KEYFOB HAVE STOPPED WORKING. THE BUTTONS FOR SLIDING DOOR/ LOCKING ABOVE CENTRE WINSCREEN INSIDE CAR ALSO NOT WORKING ALONG WITH SWITCHES LOCATED ON REAR DOOR PILLARS FOR ELECTRIC OPERATION.THE SLIDING DOOR MOTORS WORK WHEN MANUALLY OPENED. I HAVE CHECKED FUSE (No14) UNDER DASH & TRIED THE KEYFOB RE-INITIALISING PROCEDURE WITH NO JOY.
ANY HELP MUCH APPRECIATED
Hi there...
i think i can help you with this as i have just had same problem..on both doors!!!
What u need to do is get a star socket set to remove the 4 small screws on the door card(door panel).Two screws behind the inside door handle ,(which just pulls off)one at the very bottom left and one at bottom right.With door panel off you should see various rods & switches on the mechanism....push up the rod that comes through the panel with the plastic on the end.You may have to try pushing & pulling the rods to reset it to correct setting.What i did is lower window & keep trying it till you feel resistance on the outside door handle(im guessing there is no resistance & nothing happens when you pull handle from outside,right?)
Once you have got door working again what i did was remove the rod that comes up through the door panel,as if you dont when it is pushed down it will happen again.
Ive just chopped in my C8 2.2 hdi exclusive for a Toyota after enduring 11 months of problems...even the dealer couldnt remedy it in the end.
If you want my advice i would say get rid of it before it starts costing you serious money!!! The cars are great but the build quality is terrible and the parts are expensive..
Hope that is of some help
Jason.
Hja, dougcajt mi je ja...
sivac33
Citat od: sivac33;31519Mislim da pride okoli 200e, ker za xsaro pride okoli 150e.
A to je cena za par motor?kov ali za komad?
Se mi zdi kar visoka cena za en motorček ... ne bi rekel da je toliko vreden.
sivac33
Sem se zadnjič vozil s kolegovim, odpovedala je elektro ključavnica zadnjih dvižnih vrat, razlog je banalna napaka. Cevka, po kateri priteka tekočina za pranje zadnjega stekla se je snela, tekočina je namesto na steklo brizgala na ključavnico in tako je le ta posledično odpovedala.
Moti me recimo še ena zadeva, avto nima enega poštenega ročaja za zapiranje drsnih vrat znotraj, madonca v tem primeru je Evasion zakon
sivac33
Pozdrav
Rešil problem,samo plastika je poknila ki odpira zatič.3€ stroška
l.p.
Sivac
