Ženeva 2013: C5 CrossTourer
Začel/a DejanO, Februar 18, 2014, 12:29:57 POPOLDNE
CITROËN is presenting an all-road version of the CITROËN C5, the C5 CrossTourer, at the Geneva Motor Show. The new model features all the strengths of the CITROËN C5, which has sold in over 530,000 units worldwide. With its assertive personality, Hydractive III+ suspension and Intelligent Traction Control, the CITROËN C5 CrossTourer scores high on wellbeing and cultivates the driving spirit.
The CITROËN C5 is known for its class-leading roadholding. That quality is further enhanced with a new version, the CITROËN C5 CrossTourer, readier than ever for what the road has to offer with its:
> All-road design, lending the new version an assertive personality with specially designed wing extensions, lengthwise matte grey roof bars and matching 18-inch diamond-effect alloy wheels in matte grey, along with chrome-finished wing mirror housings and brushed aluminium protective fairing on the front and rear bumpers. These style attributes are combined with 15-mm higher ground clearance (at up to 70 km/h for Hydractive III+ versions). The fresh and innovative styling makes taking to the road that much more enticing.
> Optimal comfort, adapting to all road types, in particular thanks to Hydractive III+ suspension. This automotive world-exclusive CITROËN technology manages body height in real time, keeping a constant ground clearance whatever the load. The system adapts the flexibility and damping settings in line with driver input and road surface for optimum comfort and handling under all circumstances. The body height is lowered at high speeds to reduce drag. At lower speeds, the C5 CrossTourer rides at two body heights – 6 cm up to 10 km/h and 4 cm up to 40 km/h – for improved clearance. The variable body height also makes loading easier by raising or lowering the load sill. Hydractive III+ suspension is available with all engine versions apart from the HDi 115 manual and the e-HDi 115 Airdream EGS6. Again for comfort, the CITROËN C5 CrossTourer is fit with a massaging driver's seat with electric lumbar adjustment and full leather upholstery.
> Useful technologies for all circumstances, including Intelligent Traction Control, which improves traction on snow- or mud-covered roads, and the eMyWay navigation system combined with a reversing camera for easier manoeuvres.
The CITROËN C5 CrossTourer is available in two trim levels, Millenium and Exclusive, and powered by diesel engines ranging from 115 bhp to 200 bhp. The CITROËN C5 CrossTourer is available now starting at €31,950.
Zanimivo! A to je Dangel predelava ali original citroen? Èe je Dangel bo verjetno 4x4?
#2
še uradne fotke, prejšnje so pobrane iz interneta.
A ne bodo letos kao nehali proizvajati obstoječi model C5?
Ali bo v prodaji le še ta verzija?
StefZ
Očitno so tole zadnji izdihljaji :argue1: ....
Saj kaj revulocionarnega niso naredili - nekaj plastike na karoseriji in malce višji serijski položaj vožnje.
To bom jaz kupil čez nekaj let v exclusive verziji. če bi bil še 4x4 bi bilo sploh super. Pravi kameleon,.... Ravno te kombinacije z ha3 bi bile velika prednost pred vsemi ostalimi avtomobili. škoda, da niso pravi čas tega pogruntali,...
Bo pa mercedes čez nekaj let žel sadove,...
Odgovora pa še vedno nisem dobil...
MaGo5
Citat od: Zeko124;177899C5 Allroad  :D
Da bi vsaj bil!
Citat od: Lovro;177942Odgovora pa še vedno nisem dobil...
Ni planirano!
C5 se naj bi se še delal do začetka 2016. (torej skupna doba 7-8 let)
Aha...
Dejan, hvala za info.
Sem mislil, da ga že letos jeseni nehajo proizvajati.
Ale_B
Brez 4x4 žal nekonkurenčen med tekmeci.
rsm23
#12
Eto danes je bil že prvi test oz. primerjava z Insignio v Dnevniku. Očitno so jih že začeli delat:
http://www.dnevnik.si/magazin/svet-vozil/deseterobojci-manjsi-kviz-in-adut-v-rokavu
Predstavitvena brošura pa tudi že obstaja: http://www.citroen.si/Resources/Content/SI/medias_rubriques/brochures/C5_CROSSTOURER_8P_03_SI_2014_WEB.pdf
jih je bilo eno par v fr, mogoče ima gox kakšno sliko, meni je bilo škoda filma zanj
Ena slikca pa je res .. sam tudi mene ni pretirano zanimal ... Sem slikal dirkališče :)
Sem pa danes enga v Kopru videl ... črn
