DS3 cabrio
Začel/a garac, Junij 30, 2010, 01:17:54 POPOLDNE
No, pa da vidimo to cudo. Upam, da ne bo prevec pokvarilo zunanje podobe avtomobila.
Meni je kar malo čuden.
tega imaš tudi na prejšnji strani, a to ni to, preberi.si
Streha se bo spustila v zadnji del, kot pri Fiat 500c, poglej kako sliko na netu, kako izgleda
The French automaker has been tight-lipped on the possibility of a DS3 convertible ever since the popular hatchback made its debut back in 2010.  However, it appears that the rumoured convertible may now be coming to fruition.
It was reported that Citroën invited the employees to a party meant to celebrate the second anniversary of the DS lineup. The brand's top brass told the employees that they would be shown a very special car. As it turns out, the mystery car was none other than the convertible version of the DS3.
It goes without saying that cameras and telephones were absolutely forbidden, but a couple of people who saw the car reported what they saw to France's Blog Automobile. "Take a DS3, add a Fiat 500C-like canvas roof, keep the rear spoiler, stick a chrome band on the trunk, and you've got a DS3 convertible," said one employee.
The French automaker has not released any technical information about the car, but early reports suggests that the entry-level model will be powered by all-new three-cylinder gasoline engine. Thanks to the use of a small turbocharger, the mill is rated at 82 hp and 87 lb-ft (112 Nm) of torque. The other engines will be essentially the same as the ones that are found in the DS3 hatchback. The lineup will include two petrol engines, and a 92 horsepower turbo-diesel unit.
Mater, a so ga res naredili? Me prav zanima, koliko doplacila bodo zeleli za manj pleha. =)
harvey
Ne gre za manj pleha, temveč za več ega....
Malo vpogleda v notranjost. :)
Novi DS3 Pluriel... Upam, da streha spuša...
Sem glih hotu rečt...upam, da ne bo takšna kakovost kot pri pluriju, ker tisto je polomija na kubni meter...
north
Prvi DS3 cabrio že na poti do prodajalcev.
Citroën - Creative Technology
Citat od: north;137216Prvi DS3 cabrio že na poti do prodajalcev.
A to zdaj že iz tovarne dobiš registracije???:Hammer3:
Bolj so na poti do Pariškega salona. Gule verjetno so teli iz tovarne prišli kot normalni, potem so jih pa predelali v nenormalne. Registrirani so pa verjetno zato, ker jih je treba nekaj imet za testne vožnje pa to ane.
Cartier25
