Novice, Mediji, Promet, Tehnika, Akustika => Citroen in navigacija => Temo je začel/a: mdavid dne December 03, 2017, 07:06:38 POPOLDNE
Naslov: RT6 radarji v Sloveniji
Prispevek od: mdavid dne December 03, 2017, 07:06:38 POPOLDNE
mene zanima če je že kdo poskusil posodobiti lokacije radarjev v Sloveniji (vnos kordinat v datoteko). Na gpsunderground sem zasledil da je to možno, našel sem neka navodila ki mi niso čisto jasna.
Citat2nd August 2017, 08:07
These speedcams are so much better than the PSA original ones. Only in France the PSA ones are reasonable (though you have to ignore the prewarning with the ZAR) In the NLs and Italy they are very outdated. I was just on holiday and switched to these ones to get rid of all kind of old removed cams and get the newer recently placed ones. And of course this got me the ones in Germany and Switzerland as well.
 However In Italy they seem to be somewhat off, in NL this is worse. I believe this is due to some RTXmapeditor structural bias in making the conversion calculations. This has always been the case with these speedcams.
 I therefore modified them like before using radarviewer (also by mira308sw)
 Workflow:
 unpack the files to a directory on your computer or work directly on USB
 Open the cams in radarviewer - select the radar.lzw for your country - NL is map 4
 choose export to csv - this will create a radar.csv in the same dir
 Open the csv in excel (make sure you have the right delimiter or replace the delimiter in notepad)
 Create new columns for X and Y with the right offfset, and make sure the value does not exceed 15999 by using a MIN function. I added 20 to both X and Y. Copy the values back to X and Y and remove the columns again.
 Optionally you can remove the redlight cams. There are so many of them in NL that you can't zoom out of the map anymore and see anything still in cities. This is type 2 (column sc) . remove all rows with this value using the filter function
 save the csv file and import it in radarviewer and then save to LZW
 remove the csv file
 reload the speedcams. (make sure to copy the whole structure again to your USB as radarviewer also touches the directories - otherwise rt6 will not pick up the changes made)
http://gpsunderground.com/forum/forum/car-navi-system/car-gps-systems/peugeot-citroen/1324518-radyus-71-june-2017-rt6-speedcam-update/page2 (http://gpsunderground.com/forum/forum/car-navi-system/car-gps-systems/peugeot-citroen/1324518-radyus-71-june-2017-rt6-speedcam-update/page2)
lp mm
Prispevek od: SeBcHy dne December 04, 2017, 01:45:30 POPOLDNE
Za navigacijo RT6 mislim da se pri nas zaenkrat še ni nihče ukvarjal s posodabljanjem lokacij radarjev v Sloveniji. Mogoče ima kaj več infota forumaš "Dr. MadMan"?
Prispevek od: Dr. MadMan dne December 04, 2017, 10:08:17 POPOLDNE
Posodobitve radarjev sporočam na SCDB. Da bi jih pa predeloval pa nimam časa. Sem se enkrat spravil pa me je vmes inilo. Tako da če se komu da imam dostop do kompletne baze SCDB.
Prispevek od: mdavid dne December 05, 2017, 04:42:17 POPOLDNE
Jaz bi poskusil če mi seveda zraven baze daš tudi podrobna navodila kako to predalati ali dodajati lokacije. Na SCDB zame nimajo datoteke za posodobitev radarjev.
CitatAll Peugeot units produced by Magneti Marelli are not supported:
Peugeot WIP COM (RT3)
Peugeot WIP COM (RT4)
Peugeot WIP COM (RT5)
Peugeot WIP Nav+ (RT6)
Peugeot Touchscreen (SMEG/SMEG+)
lp mm
