Aktualni Citroeni => Citroen C6 => Temo je začel/a: DejanO dne Januar 27, 2016, 09:45:17 DOPOLDNE
Naslov: C6 is back!!!
Prispevek od: DejanO dne Januar 27, 2016, 09:45:17 DOPOLDNE
Citroen will bring back the C6, but only for China
PUBLISHED ON DECEMBER 29, 2015 BY JOEY WANG
Citroen is going to bring back the famous C6 name (wiki) for a new sedan for the Chinese car market, set to debut in the third quarter of next year. The new C6 will be branded as a Citroen. It will be manufactured in China by the Dongfeng-PSA joint venture.
:emot112:
citroen-c6-china-2
The new Citroen C6 will be based on the PSA EMP2 platform. Power will come from 1.8 and 2.0 turbocharged engines, and a hybrid might be added to the lineup later. Design will be inspired by the 2010 Citroen Metropolis concept car that debuted in Shanghai on the Expo 2010.
The new C6 will also have a sister at the Citroen DS brand, most likely to be called DS9. The DS9 was previewed by the 2012 DS Numero 9 concept, which debuted on the Beijing Auto Show. The concept was 'powered' by a 295hp hybrid powertrain. The DS9 will be manufactured by Changan-PSA, the joint venture that makes all the DS-branded cars in China.
by Mgid
Prispevek od: DejanO dne Januar 27, 2016, 09:49:46 DOPOLDNE
Pre-production of the new Citroen C6 has Started in China
PUBLISHED ON JANUARY 27, 2016 BY TYCHO DE FEIJTER
Pre-production of the new Citroen C6 has started in China at a factory of the Dongfeng-PSA joint venture. The new Citroen C6 is code named X81. It will debut in semi concept form on the Beijing Auto Show in April and in production form sometime around September, with a launch on the Chinese car market scheduled for late Q4.
citroen-c6-china-2
The new Citroen C6 will be based on the PSA EMP2 platform. Power will come from 1.8 and 2.0 turbocharged engines, and a hybrid might be added to the lineup later. The C6 will be the first China-made Citroen equipped with the famous hydraulic active suspension. Design will be inspired by the 2010 Citroen Metropolis concept car that debuted in Shanghai on the Expo 2010.
The new C6 will also have a sister at the Citroen DS brand, most likely to be called DS9. The DS9 was previewed by the 2012 DS Numero 9 concept, which debuted on the Beijing Auto Show. The concept was 'powered' by a 295hp hybrid powertrain. The DS9 will be launched in the first quarter of 2017, manufactured by Changan-PSA, the joint venture that makes all the DS-branded cars in China.
PS fotka 2: This is a leaked drawing of the roof of the new C6, showing a two-stage panoramic sunroof.
Prispevek od: andraž dne Januar 27, 2016, 09:56:38 DOPOLDNE
Reinkarnacija...
Prispevek od: Lovro dne Januar 27, 2016, 10:16:48 DOPOLDNE
Hec?
Prispevek od: garac dne Januar 27, 2016, 10:39:37 DOPOLDNE
ni hec, sem bral o tem pred časom
Prispevek od: Lovro dne Januar 27, 2016, 11:00:17 DOPOLDNE
Ah, prej sem bolj površno bral.
Sem mislil, da bodo starega C6 vrnili v proizvodnjo za Kitajsko. Je pa zanimivo, da bo hidro-pnevmatiko obdržal.
Prispevek od: rsm23 dne Januar 27, 2016, 12:09:15 POPOLDNE
Sam tolk lahk rečem: Svašta!
Ampak ja...je bilo pa za pričakovat da bo China only. Na ostalih trgih je itak podobna situacija kot jo Mirchi v svojem postu o drugi tematiki opisuje. oz. na kratko: Vsi bi meli, kupil pa nebi noben...
Prispevek od: XMAR dne Januar 27, 2016, 05:09:22 POPOLDNE
Zanimivo!
Očitno poševnookim gre...
Prispevek od: psihopat100posto dne Januar 27, 2016, 09:31:06 POPOLDNE
Citat od: XMAR;214445Zanimivo!
ti si rasist očitno, sram te bodi!:Hammer3:
Prispevek od: XMAR dne Januar 27, 2016, 09:45:54 POPOLDNE
Citat od: psihopat100posto;214460ti si rasist očitno, sram te bodi!:Hammer3:
Ti pa res očitno še nisi slišal omenjenega izraza!
To ni nikakršni rasizem, ampak skupno poimenovanje tako kot recimo Balkan, LGBT, ipd...
Ne bodi kreljo, no!
Prispevek od: psihopat100posto dne Januar 28, 2016, 01:22:12 POPOLDNE
očitno si nisi sam kriv za tako razmišljanje tak da ti je pol oproščeno!:Hammer3:
Prispevek od: XMAR dne Januar 28, 2016, 02:00:11 POPOLDNE
Citat od: psihopat100posto;214505očitno si nisi sam kriv za tako razmišljanje tak da ti je pol oproščeno!:Hammer3:
Daj greva na en šnopčk, to vse skupaj ni nič takega!:take_picture:
Prispevek od: fifk dne Februar 26, 2016, 03:14:59 POPOLDNE
http://www.avtomanija.com/default.asp?rb=3&id=15320
A niso te novice že bile objavljene...?
Prispevek od: gepl83 dne Februar 26, 2016, 09:55:00 POPOLDNE
Škoda. Vendar logično. V evropi ni prostora za tak avto. Sem pa vesel, da se bo vsaj nekje še prodajal. Kako bi bilo pa z uvozom takega avtomobila?
Prispevek od: Xandrej dne Februar 27, 2016, 01:02:47 POPOLDNE
Pa res si čudn. Èe še nisi videl so vsi razen sveti trojček v tem segmentu popušili. Ostaja audi, bmw, mercedes, trudijo se še lexus, jagua pa še kdo ostalo pogreb... Francozi po celi črti, renault misli da lahko z nekim latitude zraven hodi peugeot pa citroen pa sta se ustavila v segmentu nižjega razreda. Kaj češ. Oni trije pa delajo v višjem segmentu vrhunske avte zato ker med seboj tekmujejo in sveti trio je vrhunska in dobra konkurenca.
Prispevek od: garac dne Marec 04, 2016, 09:44:59 DOPOLDNE
tole pa bo terna
Prispevek od: fifk dne Marec 04, 2016, 10:54:54 DOPOLDNE
Vojna zvezd...
Prispevek od: mirchi dne Marec 04, 2016, 11:34:02 DOPOLDNE
Passat. Novi folksvagen...
Prispevek od: Romzi dne Marec 04, 2016, 11:45:23 DOPOLDNE
Res je. Volan, zici, štirje bicikli in luči ki svetijo. Včasih tudi ponoči.
Prispevek od: psihopat100posto dne Marec 05, 2016, 12:31:47 DOPOLDNE
Citat od: mirchi;216397Passat. Novi folksvagen...
je glih sodelavec kupil novega za 27 jurjev, kaka jajca, v parku na klopci se lepše sedi kak v novem pasatu, pa armatura pa volan, brezveze res. Motor je pa druga pesem, 2.0tdi vleče ko,nor, poraba 5l.
Prispevek od: jumper1 dne Marec 05, 2016, 09:34:30 DOPOLDNE
Citat od: psihopat100posto;216428je glih sodelavec kupil novega za 27 jurjev, kaka jajca, v parku na klopci se lepše sedi kak v novem pasatu, pa armatura pa volan, brezveze res. Motor je pa druga pesem, 2.0tdi vleče ko,nor, poraba 5l.
Jaz bi reku da pije 4l majo tak dobre bc da se mu da verjet!!
Prispevek od: garac dne April 13, 2016, 07:11:05 POPOLDNE
evo lepotana, spredaj passat, zadaj jaguar, vmes pa citroen, za vse tiste, ki prisegate na velike citroene
Prispevek od: rsm23 dne April 13, 2016, 07:20:43 POPOLDNE
Haha kakšen čungalunga zlepek je pa tole :Hammer3:
Volan in prestavna ročica sta premonitrana iz Cactusa...
Prispevek od: dvorjan dne April 13, 2016, 08:13:11 POPOLDNE
Za Kitajce bo dober ... =)
Prispevek od: fifk dne April 13, 2016, 08:21:45 POPOLDNE
Citroen, model zunga lunga.. Bolj ga gledaš slabši je...
Prispevek od: ModelJT dne April 13, 2016, 10:14:57 POPOLDNE
Tole je pa res samo za na Kitajsko.
Prispevek od: Tiki dne April 14, 2016, 12:23:35 DOPOLDNE
Zadaj audi, spredaj čisti vw... Pol pa že raje original švaba kupim, pa bom vsaj car na vasi... :Hammer3:
Prispevek od: Dr. MadMan dne April 14, 2016, 09:32:07 DOPOLDNE
To je pa boljš da ostane na kitajskem.
Prispevek od: Lovro dne April 14, 2016, 09:37:47 DOPOLDNE
Eh, ta jim pa ni ratal.
Prispevek od: Jaka1 dne April 15, 2016, 04:04:19 POPOLDNE
ta star c6 ga še vedn zmaga
Prispevek od: garac dne April 25, 2016, 01:18:55 POPOLDNE
top of the top
Prispevek od: zlikovski dne April 25, 2016, 07:32:41 POPOLDNE
To pa je zgleda z iste proizvodne linije pišo edino drugo marko so zalepili gor
Prispevek od: ModelJT dne April 25, 2016, 07:41:30 POPOLDNE
Sam da se ne bo po naših cestah vozil pa je vse kul.
Prispevek od: mirchi dne April 25, 2016, 08:10:20 POPOLDNE
S strani mi zgleda kot peugeot.
Prispevek od: gepl83 dne April 26, 2016, 06:26:34 POPOLDNE
V bistvu nima z citroenom nobene veze, razen spet svinjsko visoke prve havbe.
Prispevek od: veliki dne Avgust 31, 2016, 10:44:34 DOPOLDNE
Presenečenje na polno. poglej video od 0:15 naprej
https://www.youtube.com/watch?v=pmoK6IoYNyA
pa še slovenski je. Je od katerega od citroenovca?
Prispevek od: Xandrej dne Avgust 31, 2016, 11:42:04 DOPOLDNE
Kaj ti more bit da se snemaš pa to objavljaš kot tale papak? :argue1::argue1::argue1:
Prispevek od: sušo dne Avgust 31, 2016, 11:45:03 DOPOLDNE
Eeeeee dolgčas?
Prispevek od: superca13 dne Avgust 31, 2016, 03:14:16 POPOLDNE
To pa je presenečenje. Vau.
XM-ar?
Prispevek od: dexterboy dne September 02, 2016, 06:56:03 DOPOLDNE
Kdo je ta ... ''dobrotnik iz morja'' ?
Tale C6 sem pa že videl, se ga spomnim po tablicah.
(kompleks še iz časov taxija...). Bom ogledal, kaj ima Novak za eno registracijo.
Pa priimek Govekar se ne izgovarja s poudarjenim O, jao bre ljudi, ni sve u trdom L.
Prispevek od: zupi13 dne September 04, 2016, 04:00:13 POPOLDNE
Ciril je čist fajn človek, če komu ni všeč kar dela, ga pač naj ne gleda....
Prispevek od: veliki dne September 05, 2016, 08:27:09 DOPOLDNE
2 X
Prispevek od: dexterboy dne September 05, 2016, 05:10:10 POPOLDNE
@zupi13; ni bilo mišljeno kot žalitev. Mar smo bili tako nejasni?
Ali je razmišljal, da bi naredil kratki filmček samo o C6?
Veliko je za povedati. Že Xantio lahko omeni;
http://www.avtofil.si/trenutek-resnice/
Prispevek od: zupi13 dne September 05, 2016, 09:03:17 POPOLDNE
Citat od: Xandrej;222794Kaj ti more bit da se snemaš pa to objavljaš kot tale papak? :argue1::argue1::argue1:
Tole že, sicer pa nima veze, nimam nič proti nikomur! :BigThumbs:
Naslov: Odg: C6 is back!!!
Prispevek od: yubvvjh dne Maj 19, 2026, 02:17:39 POPOLDNE
Репк (http://audiobookkeeper.ru/book/3180)157.6 (http://cottagenet.ru/plan/756)CHAP (http://eyesvision.ru/strengtheningeyes/11)CHAP (http://eyesvisions.com)Jack (http://factoringfee.ru)Pros (http://filmzones.ru)Стук (http://gadwall.ru)Локш (http://gaffertape.ru)прел (http://gageboard.ru)Cash (http://gagrule.ru)What (http://gallduct.ru)Deko (http://galvanometric.ru)0023 (http://gangforeman.ru)Казе (http://gangwayplatform.ru)Clas (http://garbagechute.ru)Girl (http://gardeningleave.ru)Ансо (http://gascautery.ru)Plin (http://gashbucket.ru)Tony (http://gasreturn.ru)Pian (http://gatedsweep.ru)перв (http://gaugemodel.ru)журн (http://gaussianfilter.ru)Defo (http://gearpitchdiameter.ru)
Mich (http://geartreating.ru)Boze (http://generalizedanalysis.ru)Цург (http://generalprovisions.ru)Аким (http://geophysicalprobe.ru)Penh (http://geriatricnurse.ru)Side (http://getintoaflap.ru)Legs (http://getthebounce.ru)Урум (http://habeascorpus.ru)(190 (http://habituate.ru)Doct (http://hackedbolt.ru)Henr (http://hackworker.ru)авто (http://hadronicannihilation.ru)Stan (http://haemagglutinin.ru)серт (http://hailsquall.ru)серт (http://hairysphere.ru)приш (http://halforderfringe.ru)Марк (http://halfsiblings.ru)фрон (http://hallofresidence.ru)Jack (http://haltstate.ru)Tunn (http://handcoding.ru)Arab (http://handportedhead.ru)Cari (http://handradar.ru)Doma (http://handsfreetelephone.ru)
Slim (http://hangonpart.ru)City (http://haphazardwinding.ru)Мерк (http://hardalloyteeth.ru)Muri (http://hardasiron.ru)Brad (http://hardenedconcrete.ru)Thri (http://harmonicinteraction.ru)Maje (http://hartlaubgoose.ru)Sona (http://hatchholddown.ru)Movi (http://haveafinetime.ru)Robe (http://hazardousatmosphere.ru)Aion (http://headregulator.ru)Etie (http://heartofgold.ru)Шаст (http://heatageingresistance.ru)ZIMP (http://heatinggas.ru)Катю (http://heavydutymetalcutting.ru)Davi (http://jacketedwall.ru)Комс (http://japanesecedar.ru)эксп (http://jibtypecrane.ru)перв (http://jobabandonment.ru)слов (http://jobstress.ru)Thom (http://jogformation.ru)Попо (http://jointcapsule.ru)Крас (http://jointsealingmaterial.ru)
Sims (http://journallubricator.ru)Vogu (http://juicecatcher.ru)Иллю (http://junctionofchannels.ru)Rain (http://justiciablehomicide.ru)Wind (http://juxtapositiontwin.ru)Wind (http://kaposidisease.ru)Pete (http://keepagoodoffing.ru)Wind (http://keepsmthinhand.ru)Hitm (http://kentishglory.ru)Serp (http://kerbweight.ru)Jame (http://kerrrotation.ru)Wind (http://keymanassurance.ru)Wick (http://keyserum.ru)(Сан (http://kickplate.ru)сере (http://killthefattedcalf.ru)Stan (http://kilowattsecond.ru)Семе (http://kingweakfish.ru)трид (http://kinozones.ru/film/3180)журн (http://kleinbottle.ru)Itch (http://kneejoint.ru)фант (http://knifesethouse.ru)Nell (http://knockonatom.ru)Ряза (http://knowledgestate.ru)
Arts (http://kondoferromagnet.ru)Ново (http://labeledgraph.ru)Arts (http://laborracket.ru)Прон (http://labourearnings.ru)Jose (http://labourleasing.ru)Федо (http://laburnumtree.ru)мысл (http://lacingcourse.ru)разд (http://lacrimalpoint.ru)King (http://lactogenicfactor.ru)micr (http://lacunarycoefficient.ru)Warh (http://ladletreatediron.ru)стан (http://laggingload.ru)Бесб (http://laissezaller.ru)Sony (http://lambdatransition.ru)Roge (http://laminatedmaterial.ru)Echo (http://lammasshoot.ru)рок- (http://lamphouse.ru)Robe (http://lancecorporal.ru)Batt (http://lancingdie.ru)Gret (http://landingdoor.ru)Xbox (http://landmarksensor.ru)скла (http://landreform.ru)Dolb (http://landuseratio.ru)
аква (http://languagelaboratory.ru)хоро (http://largeheart.ru/shop/1161724)скул (http://lasercalibration.ru/shop/1163970)Vide (http://laserlens.ru/lase_zakaz/1036)шеде (http://laserpulse.ru/shop/590971)пицц (http://laterevent.ru/shop/1178623)Miel (http://latrinesergeant.ru)Wood (http://layabout.ru/shop/453557)Ligh (http://leadcoating.ru/shop/600272)Wind (http://leadingfirm.ru/shop/106197)Wind (http://learningcurve.ru/shop/466019)Scot (http://leaveword.ru/shop/466823)Рыле (http://machinesensible.ru/shop/270144)2000 (http://magneticequator.ru/shop/575902)8320 (http://magnetotelluricfield.ru/shop/446031)Pete (http://mailinghouse.ru/shop/269006)Mist (http://majorconcern.ru/shop/577237)Matt (http://mammasdarling.ru/shop/576083)Прои (http://managerialstaff.ru/shop/612379)ледо (http://manipulatinghand.ru/shop/1040431)Пара (http://manualchoke.ru/shop/601087)пере (http://medinfobooks.ru/book/3180)Love (http://mp3lists.ru/item/3180)
Vali (http://nameresolution.ru/shop/1151012)Арти (http://naphtheneseries.ru/shop/467560)упак (http://narrowmouthed.ru/shop/461830)изде (http://nationalcensus.ru/shop/1055904)стил (http://naturalfunctor.ru/shop/575221)Гонк (http://navelseed.ru/shop/103053)конс (http://neatplaster.ru/shop/455436)Quut (http://necroticcaries.ru/shop/178520)Micr (http://negativefibration.ru/shop/616089)wwwr (http://neighbouringrights.ru/shop/640882)мощн (http://objectmodule.ru/shop/447404)Bork (http://observationballoon.ru/shop/97363)Ligh (http://obstructivepatent.ru/shop/102377)Howa (http://oceanmining.ru/shop/570511)Trio (http://octupolephonon.ru/shop/571476)свое (http://offlinesystem.ru/shop/149220)Agat (http://offsetholder.ru/shop/203171)Еник (http://olibanumresinoid.ru/shop/150279)Push (http://onesticket.ru/shop/580405)Pump (http://packedspheres.ru/shop/582803)ЛитР (http://pagingterminal.ru/shop/684749)ЛитР (http://palatinebones.ru/shop/684102)ради (http://palmberry.ru/shop/688917)
поли (http://papercoating.ru/shop/584165)вида (http://paraconvexgroup.ru/shop/689601)Кетл (http://parasolmonoplane.ru/shop/1169006)Миха (http://parkingbrake.ru/shop/1169021)Вьюн (http://partfamily.ru/shop/1174015)XVII (http://partialmajorant.ru/shop/1173131)Комс (http://quadrupleworm.ru/shop/1543193)Нест (http://qualitybooster.ru/shop/1538756)Enam (http://quasimoney.ru/shop/596221)Лыче (http://quenchedspark.ru/shop/736497)laus (http://quodrecuperet.ru/shop/1073097)Robe (http://rabbetledge.ru/shop/1075244)пост (http://radialchaser.ru/shop/342816)Enha (http://radiationestimator.ru/shop/510463)Горд (http://railwaybridge.ru/shop/621457)Serg (http://randomcoloration.ru/shop/884745)студ (http://rapidgrowth.ru/shop/924331)Jorg (http://rattlesnakemaster.ru/shop/1145870)Rich (http://reachthroughregion.ru/shop/356314)Gene (http://readingmagnifier.ru/shop/514901)Rupe (http://rearchain.ru/shop/751860)Семи (http://recessioncone.ru/shop/641335)вече (http://recordedassignment.ru/shop/1029187)
тетр (http://rectifiersubstation.ru/shop/1055072)прог (http://redemptionvalue.ru/shop/1063494)худо (http://reducingflange.ru/shop/1686357)Буту (http://referenceantigen.ru/shop/1693906)клас (http://regeneratedprotein.ru/shop/1765057)Любо (http://reinvestmentplan.ru/shop/1775146)елоч (http://safedrilling.ru/shop/1819964)дире (http://sagprofile.ru/shop/1057898)42-1 (http://salestypelease.ru/shop/1849710)Шеле (http://samplinginterval.ru/shop/1876212)Колг (http://satellitehydrology.ru/shop/1897946)Сафо (http://scarcecommodity.ru/shop/1493822)Free (http://scrapermat.ru/shop/1482539)пора (http://screwingunit.ru/shop/1495817)Суда (http://seawaterpump.ru/shop/1567005)Quee (http://secondaryblock.ru/shop/1422948)Булг (http://secularclergy.ru/shop/1492640)Макс (http://seismicefficiency.ru/shop/342765)Зими (http://selectivediffuser.ru/shop/401083)Липс (http://semiasphalticflux.ru/shop/402805)Пили (http://semifinishmachining.ru/shop/1689576)Vide (http://spicetrade.ru/spice_zakaz/1036)Vide (http://spysale.ru/spy_zakaz/1036)
Vide (http://stungun.ru/stun_zakaz/1036)осно (http://tacticaldiameter.ru/shop/484061)Danc (http://tailstockcenter.ru/shop/491631)Бейс (http://tamecurve.ru/shop/499504)Пост (http://tapecorrection.ru/shop/502434)RETA (http://tappingchuck.ru/shop/488845)Разм (http://taskreasoning.ru/shop/500260)Пого (http://technicalgrade.ru/shop/1823066)СБСу (http://telangiectaticlipoma.ru/shop/1881654)Заце (http://telescopicdamper.ru/shop/1902258)Sout (http://temperateclimate.ru/shop/789466)Козы (http://temperedmeasure.ru/shop/402784)Scot (http://tenementbuilding.ru/shop/981948)tuchkas (http://tuchkas.ru/)Онит (http://ultramaficrock.ru/shop/982272)Side (http://ultraviolettesting.ru/shop/484436)
