Starejši Citroeni => Citroeni - X - => Citroen AX => Temo je začel/a: ModelJT dne Januar 31, 2014, 05:08:13 POPOLDNE
Naslov: AX in Nürburgring
Prispevek od: ModelJT dne Januar 31, 2014, 05:08:13 POPOLDNE
No takole je pa en dan en AX 1.4 D peljal po Nürburgringu in dosegel čas 9 minut in 55 sekund.
You want to lap the Nurburgring in less than 10 minutes. What car do you choose to give yourself a challenge and keep things interesting? A 52hp, 1.4-litre diesel Citroen AX, of course...
Now, an AX GT or GTI we could understand, but a naturally aspirated diesel? Surely not.
It seems one Youtube user was determined to break the 10-minute barrier though - and finally, after seven years, 118 laps, nine engines and five gearboxes, at 8:37am on August 17 2013, said AX enthusiast nailed his goal with a 9min 55sec Bridge to Gantry lap.
Apart from some sticky Yokohama AO48s, a small increase in fuel pressure, a strut bar (apparently because of the "mileage of the body") and an aluminium intake from the top-spec 1.5D engine to avoid said turret brace, the AX was mechanically stock.
Even with fully independent suspension at the rear and tipping the scales at just 720kg - thanks to a completely stripped out interior - it's quite an achievement. From the montage at the end of the video it seems driver and AX built up quite a bond, with the owner even sleeping in it in his quest to bag "the perfect lap."
http://www.pistonheads.com/news/default.asp?storyId=29332
Prispevek od: dvorjan dne Januar 31, 2014, 06:59:46 POPOLDNE
No, tale pa je car, res. To je velik dosezek.
Prispevek od: ggorenc dne Januar 31, 2014, 07:00:01 POPOLDNE
BRAVO!!! Legenda!
Prispevek od: StefZ dne Januar 31, 2014, 08:47:43 POPOLDNE
Kapo dol... Sem pogledu od začetka do konca :BigThumbs:
Èez ovinke dejansko sledi avte hitrejše avte...
Pa če 680k kilometrov :Hammer3: ima na števcu
Tip je naštudiral u nulo. :funny34d:
Prispevek od: amipick dne Februar 01, 2014, 09:15:35 DOPOLDNE
Še kako sekundo hitrejši bi bil,če nebi bilo turistov na progi.
Prispevek od: dvorjan dne Februar 01, 2014, 09:36:56 DOPOLDNE
Citat od: amipick;176659Še kako sekundo hitrejši bi bil,če nebi bilo turistov na progi.
Drzi, ampak to je pa druga umetnost. Tisti pravi vozniki raje gredo vozit navsezgodaj zjutraj, saj je cez dan preprosto prevec gnece ...
Prispevek od: mirchi dne Februar 01, 2014, 10:37:31 DOPOLDNE
Tip je car. Je pa res da je lega ki jo ma Ax tudi zelo dobra. Da v kos marsikateri avto. Da je pa motor zdrzal je pa druga zgodba. Pa ceprav osmi.
